I believe Qubes OS is eligible for that service at no fee.
It’s not like nobody will use these tools to analyze Qubes just because the official team doesn’t do it. Even if the Qubes team itself doesn’t use frontier models to analyze their own code base for vulnerabilities, the fact that the project is open source means that at any given moment, one of 8 billion people on planet earth is using their access to frontier models to analyze Qubes. So the Qubes team really has two choices: either use these tools to check for vulnerabilities themselves, or get blindsided when somebody else does it before them.
We don’t know what the Qubes team does or doesn’t do regarding the use of AI. I’ve never seen official comments on that, and most likely they have their own reasons for staying silent.
I know they’re already working on Qubes 5.0, perhaps AI tools played a big part in improving it.
All right, you got me.
I’ve read that one, but what I’m looking for is an explicit statement along the lines of “We use solution1.”
Why are those the only two choices? Why can’t someone from the Qubes community or any white hat use their access to frontier models to scan Qubes source code, then responsibly disclose any vulnerabilities they find?
Why is it that only bad actors can/will do this, not good actors?
Of course there is the slight possibility of white hats doing the work for you and giving you the results for free. But this is not 2010 anymore, people in the scene have changed for the worse, in my view.
Most importantly, this coming from a member of the Qubes project team sounds incredibly bad. LLMs are the biggest breakthrough in offensive security in a long time, and for the defense against this, it now appears as if you relied on the goodwill of volunteers that most of the time don’t even have access to the models instead of putting in the work yourself.
Isn’t that how free and open-source software works? After all, the Qubes devs are precisely that: white hats who are doing the work of developing Qubes OS for you and giving you the results for free.
I’m not sure why asking reasonable questions sounds so bad to you, but since I don’t want my personal curiosity or discussions to be misconstrued as some kind of official statement on behalf of the project, I’ll try to choose my words more carefully and try to scale back my participation in informal discussion to avoid having to defend my questions against misinterpretation.
I don’t believe that this follows logically from anything I’ve said, and I don’t believe that anything I’ve said should be interpreted in this way.
Again, I think this fundamentally misunderstands the open-source model. It seems to rest on the assumption that the Qubes developers “owe” you a certain deliverable, result, or quantity of work that meets your standards, as if you had purchased a product or signed a contract, when in reality, the program is provided to you for free, “as is,” without warranty of any kind.
It also suggests an “us vs. them” mentality, where you are on one side, and the people who make Qubes are on the other side. In reality, the nature of open-source software is such that Qubes (or any open-source software you care about) belongs to you just as much as it does to the Qubes developers. Instead of talking about the Qubes team “relying on volunteers instead of putting in the work ourselves,” I think it’d be more accurate to reframe that as the Qubes community (which I take to include everyone who cares about or is involved with Qubes) putting in the work (or not) to improve the software we care about.
Mostly because current frontier models have very high rates of refusal for cybersecurity requests, even if they are for legitimate defensive work. So if someone were to ask one of these models, be it from anthropic or openAI, to check QubesOS’ code for vulnerabilities, in order to report them to the Qubes’ team, the models or an automated system would in all likelihood refuse or block the request.
So it would take someone, likely an organization (individual researchers rarely get access) with access to frontier models with significantly reduced refusals for cybersecurity work, and few people/organizations qualify for access to such models. Qubes project, on the other hand, is almost a perfect candidate to qualify for access to daybreak red, which would give it access to open AI’s frontier models with the aforementioned vastly reduced refusals. I suspect the vast majority of open source distros would not receive access to daybreak red, but projects like Qubes and graphene have rather high chances. It is well worth it in my opinion, we have all recently seen how capable these models are at finding vulnerabilities. I urge you to suggest this to Marek.
It has already been suggested to the team.
Thank you. I hope adversaries aren’t aggressively exploiting their access right now, fearing that their long-hidden Xen/Qubes vulnerabilities are about to be exposed. (If they even had them in the first place)
To add to this discussion, the latest XSA-523 (QSB-121) was discovered by AI.
First, Anthropic’s Claude found it during its code analysis. Later, CodeAnt AI’s autonomous exploit agents found it completely on their own.
When two different AI platforms independently catch the exact same 11-year-old security flaw, it proves that whitehat AI tooling is doing great work in 2026 as well.
where is the patch and does people know if its a false postitive
The patch is in the security-testing repos. XSA-523 - Xen Security Advisories says that the issue was “validated by Stephan Lipp of Ada Logics”, so I assume it’s real and verified.
Actually, I think it has already been moved to the current (stable) repo.
Correct.
how to install it
User action is explained at the top of the QSB:
In this case, you should simply continue to update normally.
i havent got update notfications yet
