I am using a B450pro4. Can I use a USB audio adapter with this motherboard? I used to be able to use it with my HP8200 Elite SFF, but this motherboard doesn’t seem to work.
If possible, would it be possible to make it work with other USB audio adapters?
I have that same board and my sound simply stopped a few days ago. I used the green port on the back. My front ports have never been used nor plugged-in. Chasing after the usual suspects turned-up no guilty party. I will be building a new Ryzen box in a few days, so for me any fix is not necessary. You may be helped by this these AsRock posts with the same problem: No sound from B450 Pro4 Realtek Audio driver - ASRock Forums - Page 1
