I am using qubes 4.0.4.
I have installed new templates " whonix 16 and fedora 34 "
Also I have installed some programs on my fedora
I will get it back after upgrading to qubes 4.1.0 or not …
And can I backup it offline…
You have to do it online, cause the way you have to do the update is an “in-place-upgrade” → Qubes Documentation.
Your programs still will be there and available in your Fedora-34 AppVM (at least when you installed them in the F-34 templateVM.
But you should backup all the qubes, you work with daily, cause whenever you face an issue during the upgrade, it could mean you have to install all again from scratch.
and add a -y command on the upgrade command ( sudo qubes-dist-upgrade --all) if you’re setup a sys-usb cube and using usb keyboard only.
And if you doing a complete image backup of your current harddrive first by:
Thanks…
