Hi team,
So I had an incident recently where I didn’t read a dialog box well enough to understand what it meant, and I accidentally confirmed that boot-repair ( boot-repair / Home / Home )should continue with writing to a partition it couldn’t read (my QubesOS installation on /dev/sda2). Luckily it spat out a log, but it hasn’t really helped. basically it didn’t know what a LUKS partition header looks like… didn’t say what it had done to it. I think it overwrote the MBR, but I have been unable to recover and repair that, nor can I even use rescue mode to repair or even read the /dev/sda2 LUKS partition in question…
However I have been able to decrypt it and look at the files and block devices/qubes using Gnome Disks and Nautilus from a Manjaro install (/dev/sdc1). So my data is intact, and I have taken images of VMs I want to ensure survive this!
Worst warning you’re about to write over your encryption header ever …
boot-repair log:
> boot-repair-4ppa125 [20210224_0517]
============================= Boot Repair Summary ==============================
Error code 12
mount -r /dev/sdd2 /mnt/boot-sav/sdd2mount -r /dev/sdd2 : Error code 12
Error code 12
NTFS signature is missing.
Failed to mount ‘/dev/sdd2’: Invalid argument
The device ‘/dev/sdd2’ doesn’t seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?=================== /boot detected. Please check the options.
adding: 20210224_051723/ (stored 0%)
adding: 20210224_051723/sdd2/ (stored 0%)
adding: 20210224_051723/sdd/ (stored 0%)
adding: 20210224_051723/sdd/partition_table.dmp (deflated 35%)
adding: 20210224_051723/sdd/current_mbr.img (deflated 98%)
adding: 20210224_051723/sdb3/ (stored 0%)
adding: 20210224_051723/sdb2/ (stored 0%)
adding: 20210224_051723/sdb1/ (stored 0%)
adding: 20210224_051723/sdb/ (stored 0%)
adding: 20210224_051723/sdb/partition_table.dmp (deflated 43%)
adding: 20210224_051723/sdb/current_mbr.img (deflated 2%)
adding: 20210224_051723/sda1/ (stored 0%)
adding: 20210224_051723/sda/ (stored 0%)
adding: 20210224_051723/sda/partition_table.dmp (deflated 34%)
adding: 20210224_051723/sda/current_mbr.img (deflated 95%)
adding: 20210224_051723/boot-repair.log (deflated 79%)Advices: _______________________________________________________________________
You may want to retry after mounting your encrypted partitions so that the tool can verify their contents. (EncryptedPrivateDirectory - Community Help Wiki)
Are you sure you want to continue anyway? yesRecommended repair: ____________________________________________________________
The default repair of the Boot-Repair utility will restore the [(generic mbr)] MBR in sda, and make it boot on sda1.
Additional repair will be performed: unhide-bootmenu-10s win-legacy-basic-fixQuantity of real Windows: 1
============================== Restore MBR of sda ==============================
dd if=/usr/lib/syslinux/mbr/mbr.bin of=/dev/sda
Boot successfully repaired.
You can now reboot your computer.
============================ Boot Info After Repair ============================
=> Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sda.
=> Grub2 (v2.00) is installed in the MBR of /dev/sdb and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for /boot/grub. It also embeds following components:modules --------------------------------------------------------------------------- fshelp ext2 part_msdos biosdisk search_fs_uuid --------------------------------------------------------------------------- config script --------------------------------------------------------------------------- search.fs_uuid 3201f545-d634-4407-88bc-cf68ff38df99 root hd2,msdos1 set prefix=($root)'/boot/grub' ---------------------------------------------------------------------------=> Grub2 (v2.00) is installed in the MBR of /dev/sdc and looks at sector 1 of
for (cryptouuid/7ca892884d324d398aa6c51275e95b60)/boot/grub. It also
embeds following components:modules --------------------------------------------------------------------------- fshelp ext2 archelp procfs extcmd crypto cryptodisk pbkdf2 afsplitter luks gcry_rijndael gcry_sha256 part_msdos biosdisk --------------------------------------------------------------------------- config script --------------------------------------------------------------------------- cryptomount -u 7ca892884d324d398aa6c51275e95b60 ---------------------------------------------------------------------------=> Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sdd.
sda1: __________________________________________________________________________
File system: ext4 Boot sector type: - Boot sector info: Operating System: Boot files: /grub2/grub.cfg /grub2/i386-pc/core.imgsda2: __________________________________________________________________________
File system: crypto_LUKS Boot sector type: Unknown Boot sector info:sdb1: __________________________________________________________________________
File system: vfat Boot sector type: Dell Utility: FAT16 Boot sector info: No errors found in the Boot Parameter Block. Operating System: Boot files: /efi/BOOT/fbx64.efi /efi/BOOT/mmx64.efi /efi/ubuntu/grubx64.efi /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi /efi/ubuntu/grub.cfg /DELLBIO.BIN /DELLRMK.BIN /COMMAND.COMsdb2: __________________________________________________________________________
File system: ntfs Boot sector type: Windows 7/2008: NTFS Boot sector info: No errors found in the Boot Parameter Block. Operating System: Boot files: /bootmgr /Boot/BCDsdb3: __________________________________________________________________________
File system: ntfs Boot sector type: Windows 8/2012: NTFS Boot sector info: No errors found in the Boot Parameter Block. Operating System: Windows 7 Boot files: /Windows/System32/winload.exesdc1: __________________________________________________________________________
File system: crypto_LUKS Boot sector type: Unknown Boot sector info:sdd1: __________________________________________________________________________
File system: vfat Boot sector type: SYSLINUX 6.03 Boot sector info: Syslinux looks at sector 32776 of /dev/sdd1 for its second stage. The integrity check of Syslinux failed. No errors found in the Boot Parameter Block. Operating System: Boot files: /boot/grub/grub.cfg /syslinux.cfg /efi/BOOT/grubx64.efi /ldlinux.syssdd2: __________________________________________________________________________
File system: Boot sector type: - Boot sector info:================================ 2 OS detected =================================
OS#1: Windows 7 (boot) on sdb2
OS#2: Windows 7 on sdb3============================ Architecture/Host Info ============================
CPU architecture: 64-bit
Live-session OS is Ubuntu 64-bit (Boot-Repair-Disk 64bit 20200604, bionic, x86_64)===================================== UEFI =====================================
This live-session is not in EFI-mode.
EFI in dmesg.
[ 0.014704] ACPI: UEFI 0x000000009F7FC000 000236 (v01 ALWARE ALIENWRE 00000001 ASL 00040000)f98dff8980e2f542c64ddcc6b6cab59a sda1/qubes/xen-4.8.5-29.fc25.efi
2895d47544fd587b26c7e29be1295c27 sdb1/BOOT/fbx64.efi
dc3c47be2f78a78e5e57d097ae6c5c84 sdb1/BOOT/mmx64.efi
951288adcc81d2d86508f3f18d9753e0 sdb1/ubuntu/grubx64.efi
dc3c47be2f78a78e5e57d097ae6c5c84 sdb1/ubuntu/mmx64.efi
78415fb8fb9b909f8029858113f1335f sdb1/ubuntu/shimx64.efi
78415fb8fb9b909f8029858113f1335f sdb1/BOOT/BOOTX64.efi============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : notGPT, no-BIOSboot, has-noESP, not-usb, not-mmc, no-os, 2048 sectors * 512 bytes
sdb : notGPT, no-BIOSboot, has—ESP, not-usb, not-mmc, has-os, 63 sectors * 512 bytes
sdd : notGPT, no-BIOSboot, has-noESP, usb-disk, not-mmc, no-os, 64 sectors * 512 bytesPartitions info (1/3): _________________________________________________________
sda1 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sdb1 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sdb2 : is-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sdb3 : is-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
sdd2 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-farPartitions info (2/3): _________________________________________________________
sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb1 : is—ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sdb2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, bootmgr, is-winboot
sdb3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot
sdd2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinbootPartitions info (3/3): _________________________________________________________
sda1 : is-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no—usr, part-has-no-fstab, std-grub.d, sda
sdb1 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no—usr, part-has-no-fstab, std-grub.d, sdb
sdb2 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no—usr, part-has-no-fstab, std-grub.d, sdb
sdb3 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no—usr, part-has-no-fstab, std-grub.d, sdb
sdd2 : maybesepboot, no-boot, part-has-no-fstab, not-sep-usr, no—usr, part-has-no-fstab, std-grub.d, sddfdisk -l (filtered): ___________________________________________________________
Disk sda: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Disk identifier: 0xd71174a2
Boot Start End Sectors Size Id Type
sda1 * 2048 2099199 2097152 1G 83 Linux
sda2 2099200 234440703 232341504 110.8G 83 Linux
Disk sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disk identifier: 0xc51e4c89
sdb1 * 63 80324 80262 39.2M 6 FAT16
sdb2 81920 29663231 29581312 14.1G 7 HPFS/NTFS/exFAT
sdb3 29663232 1953521663 1923858432 917.4G 7 HPFS/NTFS/exFAT
Disk sdc: 29.8 GiB, 32017047552 bytes, 62533296 sectors
Disk identifier: 0x8f7b0c28
sdc1 * 2048 62524979 62522932 29.8G 83 Linux
Disk sdd: 7.5 GiB, 8004304896 bytes, 15633408 sectors
Disk identifier: 0x029e45d3
sdd1 * 64 15633324 15633261 7.5G c W95 FAT32 (LBA)
sdd2 15633325 15633387 63 31.5K ea Rufus alignment
Disk zram0: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram1: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram2: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram3: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram4: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram5: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram6: 2 GiB, 2101575680 bytes, 513080 sectors
Disk zram7: 2 GiB, 2101575680 bytes, 513080 sectorsparted -lm (filtered): _________________________________________________________
sda:120GB:scsi:512:512:msdos:ATA Samsung SSD 850:;
1:1049kB:1075MB:1074MB:ext4::boot;
2:1075MB:120GB:119GB:::;
sdb:1000GB:scsi:512:512:msdos:ATA ST1000LM024 HN-M:;
1:32.3kB:41.1MB:41.1MB:fat16::boot;
2:41.9MB:15.2GB:15.1GB:ntfs::;
3:15.2GB:1000GB:985GB:ntfs::;
sdc:32.0GB:scsi:512:512:msdos:ATA SAMSUNG SSD PM83:;
1:1049kB:32.0GB:32.0GB:::boot;
sdd:8004MB:scsi:512:512:msdos:SanDisk Cruzer Switch:;
1:32.8kB:8004MB:8004MB:fat32::boot, lba;
2:8004MB:8004MB:32.3kB:::;
zram5:2102MB:unknown:4096:4096:loop:Unknown:;
1:0.00B:2102MB:2102MB:linux-swap(v1)::;
zram3:2102MB:unknown:4096:4096:loop:Unknown:;
zram1:2102MB:unknown:4096:4096:loop:Unknown:;
zram6:2102MB:unknown:4096:4096:loop:Unknown:;
zram4:2102MB:unknown:4096:4096:loop:Unknown:;
zram2:2102MB:unknown:4096:4096:loop:Unknown:;
zram0:2102MB:unknown:4096:4096:loop:Unknown:;
zram7:2102MB:unknown:4096:4096:loop:Unknown:;
1:0.00B:2102MB:2102MB:linux-swap(v1)::;blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda
├─sda1 ext4 c5345c67-14d6-4f87-bce6-19b79ed7c3d6 d71174a2-01
└─sda2 crypto_LUKS dfd9d9f7-f5e7-48db-8c1c-5c90b1fb7018 d71174a2-02
sdb
├─sdb1 vfat 5450-4444 c51e4c89-01 DellUtility
├─sdb2 ntfs 6476614A76611DD4 c51e4c89-02 RECOVERY
└─sdb3 ntfs 984263D04263B224 c51e4c89-03 OS
sdc
└─sdc1 crypto_LUKS 7ca89288-4d32-4d39-8aa6-c51275e95b60 8f7b0c28-01
sdd
├─sdd1 vfat B8E8-80D2 029e45d3-01 BOOT-REPAIR
└─sdd2 029e45d3-02
zram0
zram1
zram2
zram3
zram4
zram5
zram6
zram7df (filtered): _________________________________________________________________
Avail Use% Mounted onsda1 766M 15% /mnt/boot-sav/sda1
sdb1 31.2M 20% /mnt/boot-sav/sdb1
sdb2 6G 58% /mnt/boot-sav/sdb2
sdb3 71.4G 92% /mnt/boot-sav/sdb3
sdd1 6.6G 12% /cdromMount options: __________________________________________________________________
sda1 rw,relatime
sdb1 rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
sdb2 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
sdb3 rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
sdd1 ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro======================== sda1/grub2/grub.cfg (filtered) ========================
Qubes, with Xen hypervisor mapper/qubes_dom0-root
Qubes, with Xen 4.8.5-29.fc25 and Linux 5.4.88-1.qubes.x86_64 mapper/qubes_dom0-root
Qubes, with Xen 4.8.5-29.fc25 and Linux 4.19.94-1.pvops.qubes.x86_64 mapper/qubes_dom0-root
Qubes, with Xen 4.8.5-29.fc25.config and Linux 5.4.88-1.qubes.x86_64 mapper/qubes_dom0-root
Qubes, with Xen 4.8.5-29.fc25.config and Linux 4.19.94-1.pvops.qubes.x86_64 mapper/qubes_dom0-root
Qubes, with Xen 4.8 and Linux 5.4.88-1.qubes.x86_64 mapper/qubes_dom0-root
Qubes, with Xen 4.8 and Linux 4.19.94-1.pvops.qubes.x86_64 mapper/qubes_dom0-rootEND /etc/grub.d/30_os-prober
==================== sda1: Location of files loaded by Grub ====================
GiB - GB File Fragment(s)0.161163330 = 0.173047808 grub2/grub.cfg 1
0.195011139 = 0.209391616 grub2/i386-pc/core.img 1
0.140052795 = 0.150380544 vmlinuz-4.19.94-1.pvops.qubes.x86_64 1
0.257671356 = 0.276672512 vmlinuz-5.4.88-1.qubes.x86_64 1
0.264549255 = 0.284057600 initramfs-4.19.94-1.pvops.qubes.x86_64.img 2
0.350688934 = 0.376549376 initramfs-5.4.88-1.qubes.x86_64.img 1===================== sdb1/efi/ubuntu/grub.cfg (filtered) ======================
set prefix=($root)‘/boot/grub’
configfile $prefix/grub.cfg====================== sdd1/boot/grub/grub.cfg (filtered) ======================
Boot-Repair-Disk session
Boot-Repair-Disk session (failsafe)========================= sdd1/syslinux.cfg (filtered) =========================
DEFAULT loadconfig
LABEL loadconfig
CONFIG /isolinux/isolinux.cfg
APPEND /isolinux/==================== sdd1: Location of files loaded by Grub ====================
GiB - GB File Fragment(s) ?? = ?? boot/grub/grub.cfg 1================== sdd1: Location of files loaded by Syslinux ==================
GiB - GB File Fragment(s) ?? = ?? syslinux.cfg 1 ?? = ?? ldlinux.sys 1======================== Unknown MBRs/Boot Sectors/etc =========================
Unknown BootLoader on sda2
00000000 4c 55 4b 53 ba be 00 01 61 65 73 00 00 00 00 00 |LUKS…aes…|
00000010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000020 00 00 00 00 00 00 00 00 78 74 73 2d 70 6c 61 69 |…xts-plai|
00000030 6e 36 34 00 00 00 00 00 00 00 00 00 00 00 00 00 |n64…|
00000040 00 00 00 00 00 00 00 00 73 68 61 32 35 36 00 00 |…sha256…|
00000050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000060 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 40 |…@|
00000070 94 73 d5 ce 2b 27 27 8b ea b0 52 f6 45 0c 85 82 |.s…+‘’…R.E…|
00000080 66 8c 68 43 23 37 0c 01 eb 5e fc 83 01 ab 57 23 |f.hC#7…^…W#|
00000090 fb e3 f5 b8 3c 26 52 18 2d 0e 8c 2d 7f 24 47 09 |…<&R.-…-.$G.|
000000a0 cc 52 b8 0d 00 01 be 4a 64 66 64 39 64 39 66 37 |.R…Jdfd9d9f7|
000000b0 2d 66 35 65 37 2d 34 38 64 62 2d 38 63 31 63 2d |-f5e7-48db-8c1c-|
000000c0 35 63 39 30 62 31 66 62 37 30 31 38 00 00 00 00 |5c90b1fb7018…|
000000d0 00 ac 71 f3 00 0e 63 3c 97 6e da a3 d7 91 8b 08 |…q…c<.n…|
000000e0 e4 11 65 32 4f b4 49 3f 2e 20 3e c7 49 d7 47 a3 |…e2O.I?. >.I.G.|
000000f0 62 67 46 e4 bb 2f a4 72 00 00 00 08 00 00 0f a0 |bgF…/.r…|
00000100 00 00 de ad 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000120 00 00 00 00 00 00 00 00 00 00 02 00 00 00 0f a0 |…|
00000130 00 00 de ad 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000150 00 00 00 00 00 00 00 00 00 00 03 f8 00 00 0f a0 |…|
00000160 00 00 de ad 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000180 00 00 00 00 00 00 00 00 00 00 05 f0 00 00 0f a0 |…|
00000190 00 00 de ad 00 00 00 00 00 00 00 00 00 00 00 00 |…|
000001a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
000001b0 00 00 00 00 00 00 00 00 00 00 07 e8 00 00 0f a0 |…|
000001c0 00 00 de ad 00 00 00 00 00 00 00 00 00 00 00 00 |…|
000001d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
000001e0 00 00 00 00 00 00 00 00 00 00 09 e0 00 00 0f a0 |…|
000001f0 00 00 de ad 00 00 00 00 00 00 00 00 00 00 00 00 |…|
00000200Unknown BootLoader on sdc1
00000070 3d 57 ab 40 3a 8d 41 5b d8 68 cc 4f 3c da 51 da |=W.@:.A[.h.O<.Q.|
00000080 46 54 3f 90 fb 77 4c 0d 1b c4 a6 24 e6 bd ce 7b |FT?..wL…$…{|
00000090 2d 71 34 7f 41 ae db c8 46 5c d3 64 a6 30 71 65 |-q4.A…F.d.0qe|
000000a0 f5 83 82 a2 00 01 62 14 37 63 61 38 39 32 38 38 |…b.7ca89288|
000000b0 2d 34 64 33 32 2d 34 64 33 39 2d 38 61 61 36 2d |-4d32-4d39-8aa6-|
000000c0 63 35 31 32 37 35 65 39 35 62 36 30 00 00 00 00 |c51275e95b60…|
000000d0 00 ac 71 f3 00 09 a1 fa f5 8a c6 a4 a2 2e 79 5c |…q…y|
000000e0 e4 53 0e a1 bb db 14 8e 01 a9 ad 94 75 d7 97 f9 |.S…u…|
000000f0 a1 b4 24 a3 fb 73 d8 ff 00 00 00 08 00 00 0f a0 |…$…s…|
00000100 00 ac 71 f3 00 05 d2 88 49 e8 b3 27 77 84 26 ca |…q…I…'w.&.|
00000110 29 77 73 5d 8b a0 b8 00 2d 6a 9a e3 f4 48 48 6c |)ws]…-j…HHl|
00000120 3c 51 a0 9b f7 67 00 67 00 00 02 00 00 00 0f a0 |<Q…g.g…|
00000200=============================== StdErr Messages ================================
File descriptor 63 (pipe:[116879]) leaked on lvs invocation. Parent PID 8356: /bin/bash
QubesOSv4.0.3-ubuntu-boot-repair-disk-Destroyer-log.log (23.5 KB)
Does anyone have a clue where to start? Closest bit of documentation I can find has been this, but it’s not quite my problem…
QubesOS: Mount and Decrypt Qubes Partition from Outside Qubes
