Hey, I came across a problem while booting qubes os from external disc. When I try to open my one time boot menu the pc is stuck on the dell logo. Can anyone help me with this?
Welcome to the forum @Killa, I’ve moved your post into the ‘User Support’ category. You can increase your chances of getting help by providing a bit more information:
- Did this ever work? … how did you install?
- Which DELL computer are you using?
- Which entry are you choosing… the one for Qubes OS or another OS (I ask, because Qubes OS wouldn’t show the DELL logo … but Windows would)
- Or are you stuck even before the boot menu?
Personally I won’t be able to help you, but answering the above might improve your chances of someone else doing so.
