EDIT:
I’m trying to attach bluetooth to sys-audio, but the USB device will not attach on Fedora templates, but others will and this works fine on the Debian 13 template. I have confirmed all this through lsusb and qvm-usb. I can’t figure out why one device would fail to connect and another not.
I’ve tried to increase vCPUs to 4 and RAM to 2GB in sys-usb, but this did not work. I can confirm sys-usb is configured correctly, other USB devices work and this one works on Debian. I can confirm sys-audio is configured correctly, I have the same setup with Bluetooth working on another machine and the behavior is observed on other Fedora-based qubes (with different, unmodified template).
Original post
I’m using the NV41 with Heads (error happens both on Novacustom’s firmware and Nitrokey’s firmware).
I’m using sys-audio with the latest RPC permissions, but attaching the USB bluetooth controller from the widget silently fails, and trying to throws an error saying it failed because it wasn’t attached to begin with, even though the widget says it is.
qvm-device usb at sys-audio sys-usb:#-## also fails silently, with qvm-device usb ls showing it is not used by a qube.
I have confirmed this with lsusb in sys-audio.
I’m not even close to familiar enough with qvm-device to know what is happening, and with no error I don’t know where to look.
