Bluetooth problem
How to make bluetooth device ACTUALLY work with other qubes. I have it paired on sys-net but it doesnt appear on other qubes. (i have a bluetooth keyboard)
when i paired it on sys-usb yes it works perfectly with all qubes BUT after reboot it doesnt remember the pairing because sys-usb is disposable vm.
Please help
  1. BT keyboard is HID device so it goes under usb sub system not network.
  2. sys-net is disposable too
Why not use a non-disposable sys-usb?
How do i make a non disposable sys-usb?
I make new vm set it to hvm mode, name is “sys-usb2” and add the usb controller device to the qube, however how can i start using it?
will i just untick the “start qube on system start” on my old sys-usb qube, and enable “start qube on system start” on my sys-usb2 and reboot the system?
im scared if the new sys-usb2 will not work and then i would be stuck with no usb devices working at all? can this happen?
I’m not sure about how to proceed exactly but what you did seems correct to me…
Well, I think it’s possible :confused: You can start by shuting down the original sys-usb and starting the new one while telling dom0 to shutdown after some time in case of a failure?
