Bluetooth Connection in Qubes OS
“I run Qubes OS from a USB installation. Now I want to connect my Bluetooth neckband headphone, but I’m unable to. Is there any solution?”
You could install everything required for Bluetooth to work in dom0, as dom0 handles sound by default it should work.
It might not be secure, but it’s up to you to define if you consider it a risk for your use case.
Or make sys-audio and connect bluetooth to it, leaving dom0 fairly secure.
As dom0 is installed on usb, the Bluetooth device can’t be used within a qube
Whole dom0?
Can’t it be done with /boot only?
Wouldn’t it resolve usb problem?
Please guide me with the complete step-by-step solution on how to connect a Bluetooth headphone in dom0
