I have a fedora-41-xfce and a debian-12-xfce based StandaloneVMs. To make sure that GTK4 apps work correctly in them I installed nautilus to test it and it worked perfectly, although it was throwing this in the terminal:
Unrecognized value "gl-disable". Try GDK_DEBUG=help
Unrecognized value "vulkan-disable". Try GDK_DEBUG=help
I’m trying to compile the test “Hello World” app as detailed in the GTK4-rs book:
First installing the necessary GTK4 dev packages:
sudo dnf install gtk4-devel gcc
and
sudo apt install libgtk-4-dev build-essential
for Debian. Next rust needs to be installed,
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
Once that is done we can create a new rust app:
cargo new my-gtk-app
cd my-gtk-app
We then determine the version of GTK4 that we have:
pkg-config --modversion gtk4
On debian it was 4.8 and on fedora 4.18. We can then add the gtk4-rs crate based on that version (for example for 4.18):
cargo add gtk4 --rename gtk --features v4_18
Next we change the src/main.rs file with the code necessary to display “Hello World” and a button:
use gtk::prelude::*;
use gtk::{glib, Application, ApplicationWindow, Button};
const APP_ID: &str = "org.gtk_rs.HelloWorld2";
fn main() -> glib::ExitCode {
// Create a new application
let app = Application::builder().application_id(APP_ID).build();
// Connect to "activate" signal of `app`
app.connect_activate(build_ui);
// Run the application
app.run()
fn build_ui(app: &Application) {
// Create a button with label and margins
let button = Button::builder()
.label("Press me!")
.margin_top(12)
.margin_bottom(12)
.margin_start(12)
.margin_end(12)
.build();
// Connect to "clicked" signal of `button`
button.connect_clicked(|button| {
// Set the label to "Hello World!" after the button has been clicked on
button.set_label("Hello World!");
// Create a window
let window = ApplicationWindow::builder()
.application(app)
.title("My GTK App")
.child(&button)
.build();
// Present window
window.present();
To compile and run it we use:
cargo run
But in the end the app shows a blank screen when a button is supposed to be shown there. It also throws the same error as the one encountered with nautilus:
This shows that Qubes default configuration of GTK4 apps is indeed passed down to it.
I tried various configurations to force hardware acceleration like:
GDK_DEBUG= LIBGL_ALWAYS_SOFTWARE=1 GSK_RENDERER=cairo cargo run
But it always results in a blank window screen. Does anyone have any idea on what could be different between normal GTK4 apps and this self-compiled GTK4-rs app and why it’s showing a blank screen despite GTK4 apps working perfectly?
