I noticed in qubes 4.0 and qubes 4.1 that i need to blacklist many modules to get rid of a lot of dmesg errors in dom0
why are they availble and some even activated in dom0?
I think some of them should never be active in dom0 but they are!
On a fresh install on my (thinkpad p1 gen2) for instance i noticed trough dmesg logs that modules where activated by default that caused errors.
So my modprobe.d/blacklist.conf looks like this atm to get rid of some of these errors
btusb
btintel
btrtl
btbcm
iwlwifi
cfg80211
bluetooth
Again: All of these modules where active on a fresh install at my thinkpad p1 gen2 with an ax200 wifi module
Pretty sure if i dig deeper i will find some more to disable…
the security implications are not that bad if i am right since all of the hardware are operating mostly in different sys vms.
Wouldnt it be way better to strip the dom0 kernel of all modules that make for example wireless comunication possible?
This would also be good to not distract “non technical users” when they discover dmesg logs.
i know i can use the qubes builder to build my own qubes with exactly the modules i need but i think some of them should never appear anyways in dom0 and should get stripped out of dom0.
or do i miss something else or messed something up?
