Ben-grande / qubes-qvm-screenshot-tool without metadata?
I’d like to recommend a very handy and cool screenshot tool GitHub - ben-grande/qubes-qvm-screenshot-tool · GitHub
@ben-grande thank you. Is automatic metadata removing from screenshots possible?
Not planned, but if someone submits a PR, I can consider.
I noticed that it lists bsd as a supported domu with qrexec support. Does that mean there is a version of qrexec and other qubes integration features for bsd somewhere?
The idea was to say that it works on systems that have Qrexec. There is no official BSD template, but I think I saw in the past one implementation that did it, and wanted to test, but never ended up testing though, so I should not have written and commuted that.
The metadata removal option would be useful, especially when screenshots are being shared outside the originating qube. Even if it isn’t built into the tool itself, having an optional post-processing step or hook for stripping metadata could be a practical addition.
