Beating Device Fingerprinting?
file:///etc/machine-id in the indivdual qube, NOT dom0, right?
Since the fact is that this OS is heavily dependent on Firefox
If that was true, the OS would be unable to run without Firefox, which is not the case.
OR better yet, use OSes that aren’t community supported.
Community support per se is not a negative factor in regards to fingerprinting.
Example: Windows is not community supported. Is it better?
I might recommend the more popular linux or BSD distros to blend into the crowd.
The biggest crowd is Android, not desktop Linux or BSD, but it doesn’t really matter, as it is impossible to have all other factors equal.
Remember to use different net qubes for each of your identities so they all have separate IPs.
If a device (user) has been fingerprinted, the IP address (which is not the same as IP) doesn’t really matter, as identification is possible regardless of it.
and maybe try to have all of those net qubes go through a dependable VPN like ProtonVPN, iVPN or Mullvad, for example.
This goes against the philosophy of Qubes OS (distrusting the infrastructure).
Speaking of which:
We may also collect information about how the Service is accessed and used (ā€œUsage Dataā€). This Usage Data may include information such as your computer’s Internet Protocol address (e.g. IP address), browser type, browser version, the pages of our Service that you visit, the time and date of your visit, the time spent on those pages, unique device identifiers and other diagnostic data.
Consider that GDPR’s paragraph (32), (43), Article 6 item 1a, and Article 7 mandate the opposite, i.e. that they actually may not do this without your explicit, informed and separate consent for each of the various purposes listed further in ā€œUse of Dataā€.
The point is: to reduce device fingerprinting, you should also consider how your most trusted parties process (and protect) your data.
In all qubes based on the same template.
ā€œKnow your enemyā€.
Random hiding from anyone will mostly get you in the trouble with everyone at some point, when it’s very or even most critical for you. Instead, establish your threat model carefully and you’ll be more closely to realizing your odds to hide.
For example, you want to hide from Google? You think you can do that? Great. I can’t. So, I’m not using it. And so on…
I’m much more of a practical application kind of guy and as such, I try not to get bogged down in correcting word usages that don’t align with precise terminology and instead was focusing on helping the OP with what they were trying to accomplish. I’m not saying there isn’t a very important place for such. I’m just saying this is how I do things and I’m pretty sure practical application is what the OP is looking for, not vocabulary.
ā€œIPā€ is common parlance for IP address. Having two identities linked by IP (IP address) can very much be a first step in associating the two
The OP appears to be trying to prevent qubes being linked to one another by third parties, hence the advice I gave.
I’m very curious as to why you’re referencing website privacy policies to me in response to my post trying to answer another member’s question about preventing fingerprinting. Maybe you meant to post that in reply to the OP. Even then, the OP’s goal seems to be to avoid having to worry about what people do with his/her data by preventing that data from being linked to him/her in the first place. That’s generally one of the main goals in avoiding fingerprinting.
How?
@webmazter
Fingerprinting is a deep subject and deep subjects should not be approached superficially, i.e. they deserve the proper attention and accuracy, so that everything is clear to all parties. We are not (or at least I am not) closely familiar with the level of every person who may read this thread now or in future. In short - the clarifications are not aimed to bog you (or anyone else) down, so don’t worry because of a small non-personal side note.
The OP does not mention parties at all.
I mostly use the forum through email. I reply to a certain message because there is no option ā€œreply to the thread as a wholeā€ (although the post shows up in the thread history too). So, technically, it may appear as a reply to your post but it may contain other feedback too.
The OP (and the topic) is about device fingerprinting with further mention about hardware footprints. The text of the policy explains that the website may collect unique device identifiers, so that is directly related to OP’s explicitly written concern.
The OP says nothing about worries or linking identity to device, although I agree with you the two are often related. Sometimes they are not though.
