My AX211 wifi card suddenly stopped working after receiving an update on Qubes. I suspect it is because of a dom0 qubes kernel upgrade. I attempted to use a newer kernel from testing with no luck.
If somebody could provide instructions on how to use a older Qubes kernel or install the required drivers in sys-net, I would be very grateful!
P.S I did find another thread on here about this issue, but seems to have been fixed in a previous kernel version. I believe my kernel version is newer.
dom0
Linux dom0 6.1.12-1.qubes.fc32.x86_64 #1 SMP PREEMPT_DYNAMIC
sys-net
Linux sys-net 5.15.94-1.qubes.fc32.x86_64 #1 SMP Sun Feb 19 07:18:46 CET 2023 x86_64 x86_64 x86_64 GNU/Linux
[ 2.835216] Intel(R) Wireless WiFi driver for Linux
[ 2.835944] xen: --> pirq=16 -> irq=40 (gsi=40)
[ 2.838190] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 2.839237] hub 1-0:1.0: USB hub found
[ 2.839251] hub 1-0:1.0: 6 ports detected
[ 2.840709] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-66.ucode failed with error -2
[ 2.840742] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-65.ucode failed with error -2
[ 2.840909] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-64.ucode failed with error -2
[ 2.841065] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-63.ucode failed with error -2
[ 2.841230] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-62.ucode failed with error -2
[ 2.841259] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-61.ucode failed with error -2
[ 2.841287] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-60.ucode failed with error -2
[ 2.841315] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-59.ucode failed with error -2
[ 2.876786] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-58.ucode failed with error -2
[ 2.876819] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-57.ucode failed with error -2
[ 2.876848] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-56.ucode failed with error -2
[ 2.876877] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-55.ucode failed with error -2
[ 2.876915] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-54.ucode failed with error -2
[ 2.876944] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-53.ucode failed with error -2
[ 2.876973] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-52.ucode failed with error -2
[ 2.877002] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-51.ucode failed with error -2
[ 2.877031] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-50.ucode failed with error -2
[ 2.877060] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-49.ucode failed with error -2
[ 2.877088] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-48.ucode failed with error -2
[ 2.877117] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-47.ucode failed with error -2
[ 2.877144] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-46.ucode failed with error -2
[ 2.877172] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-45.ucode failed with error -2
[ 2.877201] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-44.ucode failed with error -2
[ 2.877231] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-43.ucode failed with error -2
[ 2.877260] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-42.ucode failed with error -2
[ 2.877289] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-41.ucode failed with error -2
[ 2.877318] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-40.ucode failed with error -2
[ 2.877346] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-so-a0-gf-a0-39.ucode failed with error -2
[ 2.877367] iwlwifi 0000:00:06.0: no suitable firmware found!
[ 2.877379] iwlwifi 0000:00:06.0: minimum version required: iwlwifi-so-a0-gf-a0-39
[ 2.877394] iwlwifi 0000:00:06.0: maximum version supported: iwlwifi-so-a0-gf-a0-66
[ 2.877409] iwlwifi 0000:00:06.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
Things I’ve Tried
- Making sure wifi card is detected via lspci
- Trying to use a older kernel during boot grub (Tells me to load the kernel first)
- Trying VM provided kernel for sys-net
- Making sure
iwlax2xx-firmwareis installed in sys-net
