Is it possible to set aside a hard disk partition during installation and later attach that partition to VMs? It would be quick way to share data across VMs.
Yes. You can use qvm-block to attach a disk or a partition to a VM.
I don’t see mention of hard disk partition in the link. The document describes attaching usb device partitions. Is it the same for hard disk partition too?
yes. If accessible directly from dom0, it should look like:
dom0:nvme1n1 <nvme-id> ()
instead of:
sys-usb:sda <usb-key-id> ()
and should pop up in the qubes-device system tray and with the command qvm-block ls.
