Asus Zenbook 14 OLED (2022)
Remarks on installation:
At first when I first started to install QubesOS it was very slow in booting to the USB and very slow in installation I waited over 4 hours for the installation to finish with no luck.
Then I removed the Intel nvme drive and replaced it with Samsung 980 Pro nvme and it worked with very smooth fast installation.
Remarks after installation:
The system running great however there are few notes:
1- WiFi doesn’t work. (you need Ethernet connection).
2- Speakers doesn’t work. (you need external speakers tested via HDMI or headphones tested through USB-C and they will work). ( I haven’t investigated on why it’s not working and how to fix it).
3- Suspend doesn’t work.
4- Intel integrated graphics might not be working, as the CPU goes up to 90% when high in graphics video is played, and the video playback is not smooth.
5- There’s is standing issue with high resolution displays 1951 :
to overcome it open System Tools>System Manger> Appearance >Settings> Window Scaling ( set it to 2x) and when using a debian template for qubes run the following command in a terminal before launching the app; it will fix apps scaling within qubes: (thanks to [gasull])
echo Xft.dpi: 144 | xrdb -merge
5- To have a natural touchpad scrolling,and to enable tapping do the following (thanks to DVM) :
In dom0, try to add Option "NaturalScrolling" "True" and Option "Tapping" "on" to /usr/share/X11/xorg.conf.d/40-libinput.conf
You will have multiple blocks, add that line to touchpad like this:
Section "InputClass"
Identifier "libinput touchpad catchall"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
EndSection
Log off and log back in after editing.
Remarks on Asus Zenbook 14 OLED:
As you might already know the ram on this model cannot be upgraded, and qubes require a lot of rams, the more qubes you have the more rams you need; I would say to have a good experience with this OS you need at least 32GB of ram. and if you have 64GB it would be best.
layout:
‘hcl’
type:
‘notebook’
hvm:
‘yes’
iommu:
‘yes’
slat:
‘yes’
tpm:
‘unknown’
remap:
‘yes’
brand: |
ASUSTeK COMPUTER INC.
model: |
Zenbook UX3402ZA_UX3402ZA
bios: |
UX3402ZA.309
cpu: |
12th Gen Intel(R) Core™ i7-1260P
cpu-short: |
FIXME
chipset: |
00.0 Host bridge [0600]: Intel Corporation Device [8086:4621] (rev 02)
chipset-short: |
FIXME
gpu: |
02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
14.3 Network controller: Intel Corporation Device 51f0 (rev 01)
memory: |
16010
scsi: |
usb: |
4
versions:
- works:
‘FIXME:yes|no|partial’
qubes: |
R4.1
xen: |
4.14.5
kernel: |
6.1.12-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
