layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
ASUSTeK COMPUTER INC.
model: |
VivoBook_ASUSLaptop X513EAN_X513EAN
bios: |
X513EAN.301
cpu: |
11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
cpu-short: |
FIXME
chipset: |
00.0 Host bridge [0600]: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a14] (rev 01)
chipset-short: |
FIXME
gpu: |
02.0 VGA compatible controller [0300]: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] [8086:9a49] (rev 01) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
14.3 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20)
memory: |
16078
scsi: |
usb: |
1
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.4
kernel: |
5.16.18-2
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
This notebook has an Elan 1200 touchpad which does not work properly with Qubes OS. The mouse pointer does not move smoothly and there is very frequent cursor jumping. I have attempted to upgrade the LTS kernel (5.10.112-1.fc32.qubes.x86_64) to the latest available version (5.16.18-2.fc32.qubes.x86_64) with no luck. I believe this might be the same issue described in #5486.
As another forum user has previously reported for a similar model, the Suspend feature does not function reliably. During my testing, I have been unable to wake the machine up again after putting it to sleep.
Beyond those minor issues, I have had no other problems. The system works very well.
Qubes-HCL-ASUSTeK_COMPUTER_INC_-VivoBook_ASUSLaptop_X513EAN_X513EAN-20220625-165805.yml (928 Bytes)
