Asus prime b660m-a wifi d4
layout:
  'hcl'
type:
  'Desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  ASUS
model: |
  PRIME B660M-A WIFI D4
bios: |
  2801
cpu: |
  12th Gen Intel(R) Core(TM) i5-12400
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:4650] (rev 05)
chipset-short: |
  Intel® 600 Series Desktop Chipsets
gpu: |
  Intel Corporation Alder Lake-S GT1 [UHD Graphics 730] [8086:4692] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Ethernet Connection (17) I219-V [8086:1a1d] (rev 11)
memory: |
  65277
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'yes'
    qubes: |
      R4.2.0
    xen: |
      4.17.2
    kernel: |
      6.1.62-1
    remark: |
      problem at build qube. sys-usb not working. usb mouse and keyboard will freeze. just uncheck the option "create sys-usb" let dom0 manage usb or using PS/2 mouse instead
    credit: |
      @WaiFu8964
    link: |
      https://github.com/waifu8964/
Remarks
Installation
  • No problems with installation.
  • No latest kernel required.
  • No additional kernel options required.
  • problem at build qube. sys-usb not working. usb mouse and keyboard will freeze. just uncheck the option “create sys-usb” let dom0 manage usb or using PS/2 mouse instead
Basic Input
  • Keyboard- Works
  • External USB mouse [if possible to check]- Works
  • Touch-pad - desktop does not use Touch-pad N/A
  • Touch-pad supports “tap as click” and scrolling with 2 fingers works- N/A
  • Display brightness change shortcuts- N/A
  • Sound volume shortcuts- Works
  • Keyboard led and keyboard brightness change shortcuts- Works
  • Output of xinput --list from terminal of dom0 **Not Tested. command not found **
  • Check if keyboard and/or touchpad is PS/2 connected -Works
Internet and bluetooth
  • Ethernet cable connection - Works
  • Ethernet cable connection - 1Gbps
  • Wifi connection - Not tested. I do not use wifi, and i unpluged pcie wifi adapter from motherboard
  • Wifi connection - N/A
  • Bluetooth - N/A
  • Bluetooth - N/A
Suspend
  • Suspend/Resume works - works
  • Does resume breaks WiFi, - not tested
  • Does resume breaks Bluetooth, if it does, how to recover it? - Not tested
Video [increase VCPU to the qube before test]
  • Fullscreen and windowed video playback of youtube - 720p/1080p/2K/4K in Firefox. Does it drop frames? - 2160p no problem
  • Video file playback of file using mpv/mplayer/smplayer - 1080p? Higher resolutions and bitrates? - Not tested
  • Multiple displays configuration works (using available DP/Thunderbolt, HDMI or other video ports - Not tested
Audio
  • Speakers (sound playback) Wxinput --list (was sys-audio used?), works
  • Head-phones via 3.5" jack - works
  • Audio-optical (S/PDIF) output - N/A
Fans
  • Are fans silent on idle? - yes.
  • Are fans noisier than on Windows/Linux?. - Depend on load
Other
  • Have you tried running Windows 10 HVM qubes? - Not tested
  • Does CPU boost seem to be working properly? - Not tested
Specs:
  • PRIME B660M-A WIFI D4
  • Display native resolution- 1920x1080
  • Maximum possible RAM memory 128G
  • CPU score 17352
  • Number of USB Controllers * 1 USB Controller
  • Internal TPM - Yes
Thank you for the detailed report!
Thanks for the HCL report. I just submitted a pull request to add it.
