Scenario is I want to use a common modified qubes template (both debian and fedora) that I can move between same architecture hardware (e.g. workstation and laptop that are both amd64). Is that feasible?
Can customized templates be backed up / copied between physical hosts?
An extension of this is having templates and backups in the cloud and pulling to workstations for setup for common working environments as well.
I could not find direct discussion on templates that indicated if they are per Quebe OS install specific or if they are portable.
Thanks in advance.
