Apt issue with Chromium on Debian apppqubes
hello community,
i’m sometimes using chromium on one of my appqubes, unfortunatelly it start working, and I do not know how it appends.
Template is the debian-12 from Qubes repo.
The issue is with the debian apt support: when trying to update chromium-common, it fails for the reasons below.
any help welcome
sudo apt upgrade chromium-common
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 chromium-common : Depends: libc++1-19 (>= 1:19.1.4) but it is not installable
                   Depends: libc++abi1-19 (>= 1:19.1.4) but it is not installable
                   Depends: libunwind-19 (>= 1:19.1.4) but it is not installable
E: Broken packages
This happened because debian maintainers pushed a new build into stable to patch CVE-2024-12053.
Temporary workaround is to add the following to /etc/apt/sources.list:
deb https://deb.debian.org/debian bookworm-proposed-updates main
Followed by running sudo apt update, before trying to sudo apt install chromium.
source: #1089182 - chromium: Cannot install on bookworm, missing abi1-19 - Debian Bug report logs
