Anonymity Practices for Templates
Hello to all, I was working on making a non-whonix qube that routes through tor when it occurred to me that the template I was going to use probably had its timezone set to my timezone. I checked, and sure enough, it was, so I cloned the template and switched the new one to Etc/UTC.
This left me considering, “Are there other aspects of non-whonix templates that have been configured, downloaded, etc- that I need to address when using tor routing to avoid de-anonymization?”
So I thought I would make a post to ask the QubesOS community for thoughts.
Thank you for your time.
-can
Edit:
I also have set the new UTC template to update over tor.
So the short answer is “I don’t know”, but what I do know is that practical anonymity is hard if you want it done right.
I’d recommend adding your specific use-case, so anyone wanting to help can more easily understand your problem and the context surrounding it. General problems like “how do I make templates anonymous?” are hard to solve, but it’s a lot easier if you say “how do I use <this> program for <that> anonymously?” because then we can know what is a concern and what isn’t. Sometimes you want to do something a certain way, but really you want something more specific and feasible. See XY problem:
Yes, a lot. Probably also a lot of unknown unknowns. That’s why the recommendation is just to use Whonix when you need privacy. See:
https://www.qubes-os.org/faq/#what-about-privacy-in-non-whonix-qubes
