Anbox doesn't work
anbox doesn’t work. even whonix or debian. what do i need?
What exactly did you try to do to make it work and which errors did you get?
http://www.catb.org/esr/faqs/smart-questions.html
I can see only Droid and didn’t change it then. And the window will shutdown.
Try to run it from the terminal. Will it show an error?
yes. I couldn’t use.
Which error?
user@anbox:~$ anbox session-manager
[ 2023-08-11 16:05:28] [session_manager.cpp:146@operator()] Failed to start as either binder or ashmem kernel drivers are not loaded
user@anbox:~$
error is this
