I’ve spent the past 2 days battling with errors such as the following one, and even though I’ve genuinely tried my best not to ask anyone for help, it just seems as if I’m running into every error possible trying to install Qubes 4.1.2 lol and I’m honestly just getting kind of tired of doing random stuff on my computer waiting for the error to somehow resolve…
Yea but uhm onto the error, so the error occurs when I click Begin Installation and it reaches the step of the installations that says something along the lines of: “Creating lvmpv on /dev/mapper/luks-…”, then the installation stops and it says “An unknown error has occurred” and it outputs:
anaconda 32.24.5 exception report
Traceback (most recent call first):
File “/ur/lib/python3.8/site-packages/dasbus/client/handler.py”,line 496, in _handle_method
raise exception from None
File “/usr/Lib/python3.8/site-packages/dasbus/client/handler.py”,line 474, in _get_method_rep
return self. handle method error(error)
File"/usr/Lib/python3.8/site-packages/dasbus/client/handler.py",line442, in call method
return self.get method_reply
etc.
(text copied using image to text so probably not 100% accurate)
So yea if anyone knows why this error is happening or maybe even how to fix it then I’d really appreciate it, but any input in general would be appreciated ![]()
