AMD Thinkpad L14 Gen 3 Ryzen 7 PRO 5875U with Qubes 4.2.0
I got video playback including YouTube working smoothly by switching to Debian and installing pulseaudio-qubes. HDMI audio no longer works after updating Fedora, but it works on Debian.
I’m still having the same issue as Scumbag: pciback ... not ready ___ms after FLR. This delays the startup of the sys-net by about a minute.
I have installed R4.2 on my L14 and also experienced WiFi not working after suspend, which is also fixed by reloading kernel module in sys-net. I did not have this issue in R4.1 so I found that strange. The only other difference I could think of was that I used the default Fedora template in R4.1, but R4.2 uses Fedora-xfce.
When I switch sys-net from fedora-39-xfce to fedora-39, WiFi works again after suspend without needing to reload kernel modules.
So that would make it a template issue instead of a hardware compatibility issue.
Interesting. fedora-39 no longer works for me, with or without my workaround.
However, switching sys-net to debian-12-xfce fixed the issue.
Edit: It is not totally fixed. It seems to work most of the time, but still requires rebooting sys-net occasionally.
@zaz willing to test AEM trenchboot? I am just about to retire my T480 as a testing machine and wanted to get the L14 for my daily.
A week from now, I will have enough time to risk messing with my computer. However, it seems trenchboot is still not working for AMD. See their Github Milestone.
Now we have a second good report for R4.2 on the L14, so I hope it can be on the community recommended list:
I upgraded the BIOS to R1YET55W (1.32) and echo "mt7921e" >> /rw/config/suspend-module-blacklist still does not fix WiFi after suspend, but my Automated fix above does.
A fresh install of Qubes 4.2.3 works fine, but installing via Ventoy still does not work.
This issue had disappeared after a fresh install, but has been back for some time, delaying boot by 1 minute.
Does anyone know how I might fix this or at least shorten the timeout so that it gives up 2s after FLR instead of 60s?
I’m also receiving the following dom0 kernel warnings:
ACPI BIOS Warning (bug): Incorrect checksum in table [BGRT] - 0x43, should be 0x2c (20230628/utcksum-58)
[Firmware Bug]: ACPI_MWAIT C-state 0x0 not supported by HW (0x0)
and a lot of
xen:grant_table: ... still pending
messages.
