All Secrets in Vault vs. Distributing Secrets
That’s probably overkill, but it’s personal preference.
Why is it probably overkill? Because of what I wrote here:
Also, there are probably some cases where you can safely funnel files from multiple qubes into a single offline storage qube. For example, if that offline storage qube is for storing completely untrusted, nonconfidential, replaceable files, then there’s probably no harm in funneling such files from multiple qubes into it.
Encryption isn’t a panacea. You still have to decrypt it sometime (unless you never need to access the data again), at which point it’s vulnerable.
It’s possible that malware could exploit a hypothetical side channel vulnerability. For example, an attacker could theoretically use the CPU cache to exfiltrate data from a compromised offline qube to sys-net, then anywhere over the internet.
If you truly never download anything, then your entire machine is permanently offline and air-gapped, in which case you mainly just have to worry about physical attacks (e.g., theft, coercion, evil maid) and emanations (TEMPEST-type stuff). But it’s doubtful that your machine is truly 100% offline. Browsing the web involves downloading bits to your machine over the internet. Updating Qubes involves downloading and installing things.
No, banks usually keep a half-year history of transactions. If you keep your history for longer, it does make sense to put your bank statements elsewhere. Otherwise I agree that there are many use cases where it makes sense to have fewer archival VMs.
Why is that significant when the contents of B are now at risk? That’s like saying, “Our top secret files are exposed, but at least the vault we stored them in is still in good shape!”
It doesn’t matter whether we call it B' or C. That’s just an arbitrary variable we use so we can keep track of which qube we’re talking about it. The reason it makes sense to call it B' is that it was created by cloning B. That makes it easier to keep track of the historical relationship between the two. But it’s just a matter of convenience; nothing hinges on the notation.
This only works while your vault is empty. As soon as you start actually using the vault and filling it with important confidential data, the scenario I described obtains. What good is a vault you can never use without wrecking your system for using that vault?
Thanks. :slight_smile:
Not that I know of. There are, however, methods for securely transferring data from less trusted to more trusted locations. The Qubes backup/restore system is one such method and was specifically designed to achieve that goal through defensive authentication of the encrypted backup file prior to any significant operation on that file.
Because if you don’t reintegrate, you just end up proliferating less and less trusted vault clones. Remember, the scenario is:
Every time you try to “up transfer” a new file to the vault, you end up with another (less trusted) vault clone.
Agreed.
Ok, but then it’s unclear how this all works. If the idea is that there’s some way to “up transfer” without reintegration, then I think this will just turn out to be an illusion: Either there will not really be any “up transfer” in the end, or there will be some hidden reintegration.
Sure, but the devil is in the details. For example, some people think that if you have to decrypt a file/drive on a potentially-compromised OS, it’s significantly safer to leave it decrypted for only one minute as opposed to one day. But this is unlikely to make a material difference in practice. It’s unlikely that the hacker is just sitting there, watching and waiting for the opportunity to strike. More likely, malware will automatically perform some action when some set of conditions are detected or triggered, regardless of when or for how long the vulnerable window is open.
Some, sure, but you have to remember the context. The suggestion was that disposables could be used in some workflow to facilitate safe “up transfers.” Again, the devil is in the details, but here’s one way it might work:
  1. You start a new disposable.
  2. You copy/move the potentially-malicious file to the disposable.
  3. The disposable is now potentially compromised.
  4. You perform some operation on the file (e.g., convert to trusted PDF) in the disposable.
  5. You copy the desired file from the disposable to a vault.
If the disposable was compromised in step 3, then the operation in step 4 was too. The now-compromised disposable could have merely pretended to convert it into a trusted PDF, or it could have implanted malware into the output PDF, or anything else. It’s a compromised qube. It can’t be trusted. Then you directly copy a file from this compromised disposable to a vault. The interposed disposable isn’t doing anything for you. It’s just shifting the vulnerability around. You can add as many layers of indirection as you want, but unless you change something fundamental about this workflow, the result will be the same.
Depends. If you’re using a fresh disposable to download an untrusted file from an untrusted website, then it might be a bit pointless. The analogy that springs to mind is putting on a clean nitrile glove in order to pick up a piece of garbage and put it into your mouth. But still, it’s plausible that the disposable might have some benefit over using an already-compromised qube to do this.
It’s hard to say. For one thing, dispXXXX was probably running on a template with a lot more software installed than offline-slight-trust. But if dispXXXX was compromised, it’s quite possible that the file was too, in which case it depends on whether you open/run that file in dispXXXX.
This was already discussed upthread, but basically no. Merely storing a file in a qube doesn’t put that qube at much practical risk. It’s actually opening/running the file in a qube that carries most of the risk.
I’m not sure how you’d copy them except with qvm-copy (or equivalent), so I don’t know.
That shouldn’t meaningfully increase the risk. I suppose it’s theoretically possible that it might exploit some vulnerability in sha512sum, but that seems exceedingly unlikely. I’m not an expert, though.
See above for why interposing disposables often doesn’t provide the benefit people think it will.
But this ignores the point I actually made. The important question is not whether the attacker gets access to six months versus six years of statements. Rather, it’s whether the attacker gets to transact on my account as if he were me. I care almost infinitely more about the latter than the former, so I’m fine, in practice, with storing unlimited historical data in a qube with transaction authority for the account that generated that data in exchange for the convenience of not having to deal with double the number of qubes.
But that’s just me. If you care enough to deal with double the number of qubes in order to make sure that an attacker who gains transaction authority over an account does not also gain access to old statements that are no longer available from the online account itself, then by all means. I just can’t imagine myself ever saying, “The hacker may have drained my account, but at least he doesn’t know how much was in it over six months ago!”
In other words: Of course I agree that there is a theoretical confidentiality gain from segregating data that an adversary wouldn’t otherwise have access to. I just don’t think it matters enough in practice to warrant the extra hassle.
The difference is that stealing your data is a simple process which is easy to automate, whereas getting into your bank account usually requires a two-factor authentication and precise customization to your bank. Even if you banking VM is compromised, it’s quite unlikely that you loose your money (and there is also a possibility to get it back by asking the bank, in principle). But the probability to leak all your data is very high.
In my understanding, even if you store your transaction data in the same offline qube where you store everything else, it’s much more secure/confidential than storing it in any online qube.
In the original paragraph you quoted, I said “barring multi-factor authentication outside of that qube.” But sure, I see your general point. In that case, though, I’m not so worried. After all, statements generally don’t have any data the can be used directly to cause significant damage. Otherwise, sending them through the mail would be/have been too risky. Probably the biggest risk of your statement falling into enemy hands is that they now know how big or small of a target you are!
But “bank” was just an example. If it’s a crypto exchange, for example, the blockchain transactions could be truly irreversible.
Ah, true, it could just be one. But still, I personally don’t see the benefits as outweighing the hassles. There are the file transfers, then the risk of opening files from different sources in the same offline qube, or the hassle of having to wait for a disposable/qvm-copy each time I want to open one. Plus, if I someday realize I want to transfer a file out of there to use it, I now have to worry about exposing all the other data. Just keeping the files in their originating trusted qubes seems like an acceptably minuscule security sacrifice for me that will almost certainly never make any practical difference.
This depends entirely on what threat you are guarding against.
For example, if you had an account (of any sort) which you used solely to
funnel funds, there would be no threat from a hacker gaining control
over that account since it rarely has a positive balance.
But gaining access to 6 years of past transactions would be enough to
build a substantial case against you.
As always, Qubes provides the means, but it is up to the user to
determine what threat is significant for them, and how to use Qubes to
reduce that threat.
“that’s just me” is a great caveat - I wish more users would follow your
example when posting in this forum.
