After a fresh install Stuck on a bootloop after qubes loading screen
I
Im having a hard time trying to run Qubes on my Lenovo Legion 5 15ACH6H (5600H,rtx3060).
After a fresh install, the xfce loading screen appears then it reboots on its own
it’s been 2 weeks now, i basically tried everything i could think of , i installed with both the stable and the latest kernel option, i switched to switchable graphics in order for the system to use integrated graphics because i read that qubes doesn’t get along with Nvidia gpus, even changed the SSD drive, had anyone here have this problem ?
Did you finish the Initial Setup?
Or do you have this problem right after you press on a Reboot System button here?
this happened after i finished initial setup
Did you have any errors during Initial Setup?
Try to boot with disabled qubes autostart:
Maybe your sys-net/sys-usb is failing to start because of a PCI device attached to them.
Also at this screen:
You can press Esc key to show the log and check at what point is it stuck.
this is what’s showing despite finishing initial setup, and then it reboots again on its ow, i guess it’s some kinda bug , i tried with both RC 4.2.3 and 4.2.2,pressing escape didn’t help as it shows no error
Well , i got it to work thanks to that, disabled qubes autostart, and i figured that sys-usb qube is the problem here, i started it then the system froze and rebooted, good thing that it’s working finally, bad thing is that i can’t use USB drives,…
I think it’s the same issue as this one:
Hardware reset during installation and boot of R4.2 on Ryzen 9 7950X · Issue #8322 · QubesOS/qubes-issues · GitHub
thanks a ton for your help
