i can’t install the qubes contributed package qubes-polybar. So im using the regular polybar package instead…
I added the contrib repo by following the official documentation. No problems with that.
But trying to install doing:
sudo qubes-dom0-update --clean qubes-polybar
gives me this:
Unable to detect release version (use '--releasever' to specify release version)
0 files removed
Fedora 37 - x86_64 1.2 MB/s | 70 MB 01:00
Fedora 37 - x86_64 - Updates 1.8 MB/s | 43 MB 00:23
Qubes OS Contrib Repository for dom0 (updates) 6.8 kB/s | 27 kB 00:03
Qubes Host Repository (updates) 666 kB/s | 3.9 MB 00:06
No match for argument: qubes-polybar
Error: Unable to find a match: qubes-polybar
Looking at the github page for qubes-polybar it says Qubes 4.0 only, and since I’m on 4.2 Im guessing that’s why.
anyway, I installed the regular polybar instead, using:
sudo qubes-dom0-update polybar
It works fine, now I just want my system tray to show in polybar. Idk how to configure this. Do I try to reuse qubes-i3status, or is another solution needed?
Im hoping that there already is a solution available since there is the qubes-polybar contrib package, for Qubes 4.0.
