After the last update of dom0 the new kernel 5.15.81 does not boot on Librem 14 laptop. Kernel 5.15.78 works.
Does anyone have same problem?
Just updated my Librem 14, and it works fine with 5.15.81-1.fc32.qubes.x86_64. What errors does it show for you?
I use PureBoot Basic. When I try to boot 5.15.81-1.fc32.qubes.x86_64 I see only the grub parameters and then it freezes.
Do you use Coreboot or PureBoot?
I’m using full Pureboot (not Basic). Unfortunately I’m not knowledgeable enough to help you solve it. Hope someone else could do.
