4.3 RC2 badly broken
Now getting disk errors within a VM on Qubes 4.2.4, maybe I do have a bad drive…
Oct 02 13:40:11 vmname kernel: I/O error, dev xvdb, sector 2187704 op 0x1:(WRITE) flags 0x9800 phys_seg 10 prio class 2
Oct 02 13:40:11 vmname kernel: Aborting journal on device xvdb-8.
Oct 02 13:40:11 vmname kernel: EXT4-fs error (device xvdb): ext4_journal_check_start:86: comm libuv-worker: Detected aborted journal
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 34346696 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 4293337)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 4241369
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18945368 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368171)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316203
Oct 02 13:40:11 vmname kernel: EXT4-fs (xvdb): Remounting filesystem read-only
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18946568 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368321)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316353
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18946704 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368338)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316370
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18946896 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368362)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316394
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18947216 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368402)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316434
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18948136 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368517)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316549
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18948176 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368522)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316554
Oct 02 13:40:11 vmname kernel: I/O error, dev xvda, sector 18949056 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368632)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316664
Oct 02 13:40:11 vmname kernel: EXT4-fs warning (device xvda3): ext4_end_bio:368: I/O error 10 writing to inode 131294 starting block 2368827)
Oct 02 13:40:11 vmname kernel: Buffer I/O error on device xvda3, logical block 2316859
Oct 02 13:40:17 vmname kernel: blk_print_req_error: 9 callbacks suppressed
Oct 02 13:40:17 vmname kernel: I/O error, dev xvda, sector 17474752 op 0x1:(WRITE) flags 0x9800 phys_seg 3 prio class 2
Oct 02 13:40:17 vmname kernel: Aborting journal on device xvda3-8.
Oct 02 13:40:17 vmname kernel: EXT4-fs error (device xvda3): ext4_journal_check_start:86: comm systemd-journal: Detected aborted journal
Oct 02 13:40:17 vmname kernel: I/O error, dev xvda, sector 17455104 op 0x1:(WRITE) flags 0x9800 phys_seg 1 prio class 2
Oct 02 13:40:17 vmname kernel: Buffer I/O error on dev xvda3, logical block 2129920, lost sync page write
Oct 02 13:40:17 vmname kernel: JBD2: I/O error when updating journal superblock for xvda3-8.
Oct 02 13:40:17 vmname kernel: I/O error, dev xvda, sector 415744 op 0x1:(WRITE) flags 0x3800 phys_seg 1 prio class 2
Oct 02 13:40:17 vmname kernel: Buffer I/O error on dev xvda3, logical block 0, lost sync page write
Oct 02 13:40:17 vmname kernel: EXT4-fs (xvda3): I/O error while writing superblock
Oct 02 13:40:17 vmname kernel: EXT4-fs (xvda3): Remounting filesystem read-only
try to boot kali linux live from a usb stick and to mount the volume.
Then do a dd if=/dev/zero of=fill.bin to some directory you like. So you see if you get I/O errors while your drive fills with zeros. Stop with ^C after some time.
Dont forget to remove fill.bin.
