[user@dom0 ~]$ cat /etc/os-release
NAME=Qubes
VERSION="4.1 (R4.1)"
ID=qubes
VERSION_ID=4.1
PRETTY_NAME="Qubes 4.1 (R4.1)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:ITL:qubes:4.1"
[user@dom0 ~]$
Well, this is strange. Did you use the dist-upgrade script in dom0 to go from 4.0 to 4.1?
Can you do xentop
in dom0 and check the Xen version at the top?
I don’t remember how I did the upgrade…
xentop
says Xen 4.8.5-37.fc25
You are still running on 4.0, it’s EOL so you need to upgrade asap.
That’s why you can’t use the script (wrong qrexec version in dom0) and why you can’t upgrade to fedora 36 (packages not available for 4.0).
Refer to Qubes OS 4.0 has reached EOL | Qubes OS to upgrade.
I restarted the upgrade to 4.1 and now fedora 36 is working fine.
Thank you so much DVM for your help !!!
Glad we were able to find the issue!
