Can you try this command in sys-net and see if you get anything? I want to make sure it’s not just ping that’s not working.
curl -IL 1.1.1.1
curl -IL 1.1.1.1
[user@sys-net ~]$ curl -IL https://qubes-os.org
HTTP/2 301
date: Tue, 16 Jan 2024 20:26:52 GMT
cache-control: max-age=3600
expires: Tue, 16 Jan 2024 21:26:52 GMT
report-to: {“endpoints”:[{“url”:“https://a.nel.cloudflare.com/report/v3?s=2wYOL6BCnInuEc%2B8d2SSZxJBup%2FO54y%2B7tnZbY3dK7JlsyuhzsWfkCsMyt4h0zDW%2FfEeEJebYQqdSGtxenVOBOQuoqqx%2FOdF0Kl2Hs%2B%2B%2BRRDKrZpzjPsE4OFJx1bq4g%3D”}],“group”:“cf-nel”,“max_age”:604800}
nel: {“success_fraction”:0,“report_to”:“cf-nel”,“max_age”:604800}
strict-transport-security: max-age=31536000; includeSubDomains; preload
x-content-type-options: nosniff
server: cloudflare
cf-ray: 8469188f686618cc-EWR
alt-svc: h3=“:443”; ma=86400
HTTP/2 200
server: GitHub.com
content-type: text/html; charset=utf-8
last-modified: Mon, 15 Jan 2024 18:43:50 GMT
access-control-allow-origin: *
etag: “65a57ce6-77c0”
expires: Tue, 16 Jan 2024 13:42:11 GMT
cache-control: max-age=600
x-proxy-cache: MISS
x-github-request-id: 2638:5734:BEA43B:FE5585:65A6855B
accept-ranges: bytes
via: 1.1 varnish
x-served-by: cache-ewr18130-EWR
x-cache: HIT
x-cache-hits: 1
x-timer: S1705436813.950127,VS0,VE14
vary: Accept-Encoding
x-fastly-request-id: d7e663ba900cbbec5f8a187ecf040d1b79ac7ce5
content-length: 30656
[user@sys-net ~]$ curl -IL 1.1.1.1
HTTP/1.1 301 Moved Permanently
Server: cloudflare
Date: Tue, 16 Jan 2024 20:28:28 GMT
Content-Type: text/html
Content-Length: 167
Connection: keep-alive
CF-RAY: 84691ae82ccc6a52-EWR
HTTP/2 200
date: Tue, 16 Jan 2024 20:28:28 GMT
report-to: {“endpoints”:[{“url”:“https://a.nel.cloudflare.com/report/v3?s=CdS8ebaLEUzhGbNcfdRemcHjKxvaOMhH6%2B1GFwJcbmErG2V%2BXpvNoe0ln0TtyL%2F9OR81L7Gin1A30pE6wZ%2BQT9rz3PxB%2F3MaDMbUS60xvoIBd6DuT3ML7TA%3D”}],“group”:“cf-nel”,“max_age”:604800}
nel: {“report_to”:“cf-nel”,“max_age”:604800}
last-modified: Fri, 21 Jul 2023 21:11:33 GMT
served-in-seconds: 0.002
cache-control: public, max-age=14400
cf-cache-status: HIT
expires: Wed, 17 Jan 2024 00:28:28 GMT
set-cookie: __cf_bm=imb6.Wtc.SX_Z6HvmvExvtKhzgcwyF1awOkkE_pnpl4-1705436908-1-AW0TlzAfshcDv0orNRwy7/Da3Y7cqppO4c0/GzwNft6bZMZHjAkuqBOg6uei2CZtXF+2wHGtfbiQvxCtgXlFALc=; path=/; expires=Tue, 16-Jan-24 20:58:28 GMT; domain=.every1dns.com; HttpOnly; Secure; SameSite=None
server: cloudflare
cf-ray: 84691ae89ff442e6-EWR
Okay, so your network is working. Are you really unable to ping anything from sys-net?
[user@sys-net ~]$ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.71 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.987 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=2.53 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=1.30 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=1.19 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=1.35 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=1.14 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=2.54 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=1.16 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=2.94 ms
I was talking about external IPs and domains like 1.1.1.1 and qubes-os.org for example.
[user@sys-net ~]$ ping qubes-os.org
PING qubes-os.org (172.67.208.186) 56(84) bytes of data.
and
[user@sys-net ~]$ ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
and
[user@sys-net ~]$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
all just hang with the blinking cursor
Maybe you are not allowed to use ping on your external network. Can you run the same curl command, but this time in sys-firewall, to see if you can reach the Internet?
[user@sys-firewall ~]$ curl -IL 1.1.1.1
Server: cloudflare
Date: Tue, 16 Jan 2024 20:40:37 GMT
Content-Length: 167
CF-RAY: 84692cb12a5d0f45-EWR
HTTP/2 200
date: Tue, 16 Jan 2024 20:40:37 GMT
report-to: {“endpoints”:[{“url”:“https://a.nel.cloudflare.com/report/v3?s=UxXhGTocMR9Crl9ycy8bv49KxgDGc1Gl0KvtKUbSPIkojNaBRD19hi2WpKJMj%2BLqdnQmfFwlmy38phIjhQK8zTnmkXv2WdrUV34C0Riht%2FinZq%2B%2FRFxlM18%3D”}],“group”:“cf-nel”,“max_age”:604800}
expires: Wed, 17 Jan 2024 00:40:37 GMT
set-cookie: __cf_bm=Fstg7u2MfAtyeE3IAxTDhtvA.9NwM.7lY9NouXFSJcc-1705437637-1-ARyN55RimGPN5DB61msWfErObSOmqbJ+tjvdLTW6ijDycRlSjCurzwqhNies0PLwjEvHe+XBq6fJan4Ar7WELM0=; path=/; expires=Tue, 16-Jan-24 21:10:37 GMT; domain=.every1dns.com; HttpOnly; Secure; SameSite=None
server: cloudflare
cf-ray: 84692cb1b9350f99-EWR
Well, it means that you should be able to download and upgrade dom0.
Do you get the same problem when you run this command again from dom0?
sudo qubes-dist-upgrade --release-upgrade --dist-upgrade
Errors during downloading metadata for repository ‘qubes-dom0-cached’: - Curl error (37): Couldn’t read a file:// file for file:///var/lib/qubes/updates/repodata/repomd.xml [Couldn’t open file /var/lib/qubes/updates/repodta/repomd.xml]
…All mirrors were tried
Try this command in dom0 to disable the problematic repo and run the upgrade script again using the same command as before.
sudo dnf config-manager --set-disabled qubes-dom0-cached
did new command and upgrade failed again with the same firewall error listed above
is reboot needed after ```
Try switching to sys-net instead. Add the qubes-updates-proxy service and restart sys-net:
qvm-service sys-net qubes-updates-proxy -e
After sys-net is restarted, use this command:
sudo qubes-dist-upgrade --release-upgrade --dist-upgrade --updatevm sys-net
[user@sys-net ~]$ qvm-service sys-net qubes-updates-proxy -e
bash: qvm-service: command not found…
Run the commands in dom0, don’t forget to restart sys-net after adding the service.
Ran the command in dom0, restarted sys-net, gave the upgrade command - and it stopped at the same place again
The last line if dom0 is : 'Error: There are no enabled repositories in “/evc/yum.real.repos.d”/
What error are you getting?
It seems to need the cached repo.
Enable it again and try to clean everything up before running the upgrade script again:
sudo dnf config-manager --set-enabled qubes-dom0-cached
sudo dnf clean all
The last line in the pop up sys-firewall terminal is " Press Enter to exit’ which then gives The last line if dom0 " : 'Error: There are no enabled repositories in “/evc/yum.real.repos.d”/ "
