My laptop is a 1920x1080 display. However, when I go into the settings>display the resolution only goes up to 1366x768 which causes the qube manager, especially when creating new qubes to cut off, which then I need to move my panels.
Is there any way to force 1920x1080 or add it to that menu?
Dom0 runs Fedora 32, so running something at startup is the same as for Fedora. For example, you can do it in
Menu – System Tools – Session and Startup.
